Posted by MNGB on August 09, 2009 at 17:28:40 from (69.42.227.214):
Hi all I have a B with a Zenith carb carb has the adjustable main jet, I can not get it to idle below about 1000 r's top end is at what the book says it should be 1500 no load, also with no load the gov / engine surges and finally settle down at 1000 rpm's. In gear it revs up fine to about 1500 and will idle down to about 8/900. I have adjusted the gov to carb rod per the manual, tried to adjust the surge spring on the bottom of the gov to no avail, have adjusted the idle and main jet nothing. Is it normal the when the main jet is turned co,pletely in that the engine runs just the same? Under load it will not make power but just setting idleing at 1000 r's it makes no difference.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
