Posted by Bob M on August 12, 2009 at 11:31:26 from (151.190.254.108):
In Reply to: Why does it stall? posted by Iowaboy on August 12, 2009 at 06:08:10:
I agree with Andrew - likely the long trailer ride dislodged some crud in the carburetor and it's now partially plugging one of the fuel metering orifices.
Or if it's a steep climb on/off your trailer water and junk in lying at the bottom of the float bowl got "sloshed" into a fuel orifice.
Whatever the cause suggest dropping the carb bowl. It can be done without removing the carburetor.
Once the bowl is off thoroughly clean the interior and blow out all the passages. Also blow out the passages in the throttle body casting, and remove/clean the fuel inlet screen (it's located behind the fuel line inlet nut).
Reassemble using a new gasket and see if it solves the problem.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
