joe, you are prolly gonna need to build a puller to get it off. get a stout beam, c-channel, or square tubing, heavy wall. big bolt and a nut welded to the center, and the use the holes in the cast center where the weights bolt up to anchor the puller. pb blaster everything up real good, then get the puller on and tighten it up, leave pressure on the center bolt that pushed against the axle stub. you may need some heat and some good whacks on the center bolt to get it to pop loose. them are a devil when they are stuck on.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
