John T said: (quoted from post at 17:46:56 08/15/09) Okay, when not running if you turn lights on she swings to + charge THE AMMETER IS BACKWARDS probably cuz it was originally pos ground but got switched to neg ground and no one reversed ammeter leads.
If its charging when running at fast RPM with a backwards ammeter (like you have) it would swing over to - discharge THAT WILL TELL IF ITS CHARGING OR NOT even tho ammeter may be backwards
Measure battery voltage just setting it should be around 6.3 volts for a 6 volt or 12.6 for a 12. Then when running at fast RPM if shes charging the battery voltage will rise to the 6.5 to 7 or so range, twice that on a 12 volt system.
I will get into it tonight. Will post results later. I don't think it is charging because at high rpm idle the needle of the ammeter is at dead center.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
