Posted by ScottyHOMEy on August 16, 2009 at 18:26:01 from (64.222.221.57):
In Reply to: Farmall model b posted by Tom Watkins on August 16, 2009 at 17:09:47:
Up at the front and underneath the left side of the tractor,just behind the center line of the ront wheels, you should see a hole in the bottom of the casting. If things are originalor anyplace near, you should see a pipe coming down through there, with a cap of some sort on it. The original had Mickey Mouse ears on it, but it could be any kind of cap. This is your radiator/cooling sytem drain. If there's nothing poking out, look above that, inside the casting, for an elbow with a pipe and cap or maybe even a simple plug in the elbow casting that might be the drain.
There are other issues that could be causing you to overheat, but I shouldn't doubt that it would benefit from as good a flushing as you can do in a thermosiphon system.
Drain it and, with the drain open, run a garden hose down through the cap for ten or fifteen minutes. While that's running, mix a couple of pounds of Arm & Hammer Washing Soda (NOT baking soda -- the washing soda will be right next to the 20-Mule-Team Borax in the laundry detergent aisle in your supermarket) into a two-gallon or larger pail. Mix it enough to dissole thoroughly, replace your drain plug, pour the soda and water solution in and add water to fill.
Then run the tractor and let it heat up. YOu don't want to let it overheat to wher eit causes damage, but energy like heat promotes the speed of chemical reactions, so let it warm right up. The thermosiphon is actually a pretty efficient system and it will circulate pretty actively when it heats up. Let it circulate. The first shot will likely get a lot of the crud out of the tubes on your radiator, as well as start to work on the pockets of sediment that build up at the rear of your head and around the #3 an #4 cylinder sleeves in the block. Run it until it gets good and warm and stop if it overheats again, then drain.
What comes out should be a nasty black. You can then try a running it with straight water to see if things are better, or give it another flush with hose water (after letting it cool down!) followed by another flush with washing soda.
If that doesn't ease the problem, you may have more sludge (it can really pile up!) than flushing will take care of, in which case you might pull the radiator and the upper engine outlet (that is also your fan support bracket) and the lower inlet, and nose a pressure washer in there to try and break up the clot.
If your overheating is not related to the cooling system, there are valve and ignition timing issues that could be in play, but I'd start with the easy stuff.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
