Posted by ScottyHOMEy on August 16, 2009 at 19:56:12 from (64.222.221.57):
In Reply to: oil detergent or not posted by tim mcconley on August 16, 2009 at 19:23:16:
david g is on the mark.
A little kerosene and a brush used to clean up the top end, followd by a good drain and cleaning of the pan is all you need. Then run a detergent oil.
Detergent in terms of a motor oil is not the same term as doing your laundry. In oil, it is not a solvent, it is a surfactant, rated for its ability to hold particles and sludge n suspension to get them to the filter, or to hold them in suspension until drained. It does not imply (scrubbing bubbles) that will break loose clods that will clog the oil galleries. It can actually be helpful over time by allowing particles in the soft surface of inaccessible sludge to lift and be suspended or filtered out.
As far as the bearings, I think the face of the conventional main and rod bearings is a much later and more durable alloy than babbitt. They are most definitely not poured babbitt bearings.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
