I wouldn't put a torch on the pistons. Try putting the piston into varnish/gum remover cleaner for a few days. If you have access to an ultrasonic cleaner, put the pistons and heated cleaner in and let sit for a few hours.
You may have to repeat this a few times. Be patient.
The issue with a torch or oven is that you're heating both the piston and the rings at the same time, which doesn't do you a lot of good as far as forcing the parts apart. The downside is that you might easily distort the piston if not heated correctly with a torch, and you need some way of anchoring the piston so that you can put leverage against the rings. If the piston is aluminum, you run the risk of damaging the ring grooves trying to pry the cast iron or steel rings out.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
