Posted by glennster on August 19, 2009 at 06:02:53 from (99.139.125.51):
In Reply to: caM geAR PRICES? posted by tn terry t on August 18, 2009 at 17:06:46:
i have a friend that owns a custom gear shop. many of the aftermarket gears are made overseas, or, the blanks are made overseas and final machining done domestically. his shop either uses domestic produced blanks and then he does the machining, heat treating , hard chroming ect, or if a suitable blank is not available, they hog the blank out from a billet and build the gear from there. probably a stock application will get along fine with an import gear, but if it is a severe use, ie puller or hot rod, the domestic gear would be the better choice. big problem is going to be cost. import gears are quite a bit lower cost, mainly due to labor costs.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
