Check the fuel flow to the carb., by disconnecting the line at the carb and drain out at least a quart or more. Is the fuel flow a steady stream or does it start to slow down? It could be the vent in the gas cap. The screen in the sediment bowl could be partially blocked. Can you drain the gas out of your tank and then remove the entire sediment bowl assembly from the tank. Mine was partially plugged and would not allow enough gas through it. Do you have an inline filter? Some cause a problem. Remove it. The inlet to the carb may have a brass screen in it. It should be attached to the fuel line, but maybe it broke off and it is stuck in the carb an it could be plugged. SDE
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
