Posted by Dan Swanson on August 19, 2009 at 18:57:14 from (63.172.252.199):
Was working summer fallow today with my 806 and a 14' set of sweeps and dead rod. It has always seemed the tractor was under more load than it should be. I set the cylinder so that I was getting the weeds with the rod but still had weight on the wheels of the sweeps. I have an old case cylinder with the control pin that hits an adjustable collar on the ram for dept control. Any way for what ever reason I put the valve into float position,(pushed it clear forward). The tractor immediately smoothed out and ran a lot easier. Wasn't acting like it was under any load as before. So I played with several times and everytime I let the sweeps down and left in the normal position, the tractor seemed loaded more. Put in the float position and the tractor ran a lot better like it should. Might the problem be that the valve is constantly bypassing and needs rebuilt. Or, might it have something to do with the case cylinder? I am going to switch the hoses to the right set of outlets that are controlled by the right lever and see if it is any different. Any ideas? Thanks Dan
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
