Re: SWD6 won't start.
Posted by mkirsch on August 20, 2009 at 05:18:18 from (64.80.108.57):
In Reply to: SWD6 won't start. posted by Todd L on August 19, 2009 at 20:08:03:
On any tractor that was simply driven to a spot, shut down, and left for X years, the MINIMUM you need to do is:
1. Drain all old gas and rinse out the gas tank with fresh gas.
2. Remove the carburetor, clean THOROUGHLY, install rebuild kit.
3. Replace points, condensor, rotor, cap, wires, and plugs.
4. Change the engine oil and filter before you even turn it over.
5. Remove and clean all heavy battery cable connections.
6. Charge battery.
Feel free to add anything I might have missed.
You can fiddle all you want but in the end you will end up doing everything I listed above to get the tractor running right, and probably more.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
