One other thing to check. When you had the float out, did it get bent? I was having the same issue, after I found what seems like 5 pounds of leaves and debirs in the tank. Got all that cleaned out, if worked better, but still wanted to stall and run lean, then I took carb apart again, and found side one of the float got bent a little and was hitting on the side of the carb....and would not let the float move freely, henceforth, the needle would not open. The way to check that is to take the drain plug out of the bottom of carb, see if you have a steady flow coming out of there, let a couple quarts drain out. If you do not have a steady flow, then you have an obstruction in the fuel supply system, if you have good flow, then you have something in the high speed jet in the carb. Jim
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
