Posted by John T on August 20, 2009 at 15:05:56 from (66.244.97.31):
In Reply to: HOT COIL posted by Bonnie Tallman on August 20, 2009 at 14:26:47:
On that 12 volt tractor you claim youre using a 12 volt coil, and thats all fine n dandy IFFFFFFFFFFFF its really a full true 12 volt coil.
I say that because if a coil is labeled: "12 volts for use with (or requires) external ballast resistor" its in reality a 6 volt coil and indeed requires the external ballast (just like it says DUH) otherwise it overheats badly.
A full true 12 volt (some call internally ballasted) coil may be labeled "12 volts" or "12 volts NOT for use with ballast resistor" and thats the kind you need on a 12 volt system with no external ballast. Its internal primary winding resistance between its lil + and - terminals will be in the 2.5 to 3.5 or so ohms range if its a full true 12 volt coil no ballast required.
Theres a condensor inside the distributor thats in paralell with the points, Im not sure whats going on with one at the coil unless its there to reduce radio interference.
Even the right coil (or coil + ballast) gets fairly hot if the ignition is left on a good while n shes NOT running.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
