I cleaned the switch box and seem to get some charging. If I turn the switch to high charge it shows a small charge on the amp meter. At low chaarge it shows nothing. If I turn on the lights I show a discharge and it doesn't come back to a charge after running for several minutes. If I slowly turn the lights from dim to high and back to dim I show a good charge half way between. I do not get 7 volts at the battery however. I took off the gen bracket and cleaned the block and gen bracket to make sure I have a good ground there also. It is a new battery so maybe it won't show a charge on low but it should with the lights on shouldn't it?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
