Posted by tbraley on August 21, 2009 at 06:09:27 from (67.142.164.24):
I have a manual that tells you how to bleed the system, it says:
"To bleed the system, fill reservoir to the bottom of filler hole then start engine and cycle system until any air is bled from system. Recheck reservoir fluid level and add fluid as required"
Now I am NEW to this so this may be a stupid questions. I had to change a hose for the back hoe and now it works very slow and is very week.
It says to fill to the bottom of filler hole, Where is the "bottom of filler hole"?
Do I take the filter out to see this?
I filled the Hydraulic tank up and started the engine. I had left the cap off and nothing would work. When I screwed the cap to the Hydraulic tank back on the hoe would work but was slow and weak.
Now I had to unscrew 3 lines that go under the hoe seat to change the new line. So I assume air is in the lines.
The direction really don't make any since to me. Can any help me on bleeding the system?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
