Hi, I assume you are referring to the seal on the drive shaft of the fuel injection pump If the drive shaft has a groove worn in it a new seal will not fix the problem. When replacing the seal besure to lube the seal and shaft seal lubricant. The seal must be seated squarely and flush to surface of pump. I use a deep socket to seat the seal.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
