Posted by Jim Becker on August 23, 2009 at 07:53:46 from (173.57.157.82):
In Reply to: 130 farmall lift posted by kenneth house on August 22, 2009 at 18:27:35:
I agree with the first half of Hugh's comments, but go a different direction on the second half. I'll add one more question, did this fail all at once or did it gradually loose lifting power?
30 psi is in range for the system when the regulator valve is open (system idle). Particularly if it failed all at once, you may have a stuck regulator valve. If there is fluid in the system, the first thing I would check is a plugged orifice and screen. It is easy to check (through the pipe plug in the head) and the likely problem.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
