Re: what about the M?
Posted by sflem849 on August 24, 2009 at 08:23:37 from (66.254.196.101):
In Reply to: what about the M? posted by Bob S. on August 23, 2009 at 19:37:00:
I will help in SE Wisconsin. If you needed a place to store it I have a ton of room on my farm.
To store it:
- PUT ANTIFREEZE IN IT!!!!!!!!! I know everybody has said it, but I have to beat the dead horse. It is not just the antifreeze effects that will help you out. Like they said you have to pull all the plugs on the motor (3?) and drain the radiator to PROBABLY get all the water out of the system. If it were me and you insist on doing it that way I would leave the ignition off and crank it a bit to push the water out of the water pump and voids. Just a thought, I never heard it anywhere else.
- Oiling cylinders either with actual oil or when I was at the marina we had FOGGING OIL that did this. You would spray it in the plug holes and crank it with the plugs out for a bit. This would oil the cylinders to keep them from freezing up on you.
- Sta-Bil (Possibly SeaFoam) in gas to stabalize it and protect you from water problems. Be sure to run the tractor after you do this.
- Cover exhaust
IMHO ;) these things should be done EVERY WINTER, INSIDE OR OUTSIDE!
It is never going to hurt to cover it with a tarp, but (as said) don't attatch to ground. This will lock in moisture and create even more rusting and problems. You should smell how rotton a boat smells when it is shrinkwrapped wet!!!
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
