I have heard of people using heat, in that they heated to around 400*F in an oven so than it would slide right onto the crankshaft. Others I have heard of making a tool like the one you are talking about for I have no idea of where you might find one. The way I put mine on my Regular is rather frowned upon as it places a large horizontal load on the ball bearings holding the crankshaft. Mine I used assembly lube on the flywheel surface, than started it almost halfway on with a rubber mallet. Than I used a series of bolts and large washers and spacers threaded into the tapped holes (the ones that hold the flywheel housing) on the block to pull the flywheel on. I had no trouble as long as it is pulled evenly, like mine i only did 1/2 turn on each bolt and went around in a circle. Than using a large tap i ketp the two half circles lined up for the lock pin. To get the pin in I used assembly lube than threaded it onto the end of a slide hammer and it went in pretty easy.
Hope this helps you
-Jordan
This post was edited by J.J. from Afton at 20:54:54 08/24/09.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
