47 Farmall H won't turn over
Posted by wfd2 on August 25, 2009 at 19:27:38 from (68.245.141.25):
Hello,
About a month ago I purchased my first Farmall H. I knew that the generator and the VR was disconnected, but it had a new 6v battery and started and ran well. The new battery is a Napa 6v commercial battery that turned over the tractor very well before. The tractor is equipped with a distributor.
Rewiring the 6v system is on my to-do list (Using the troubleshooting and wiring charts from this forum, THANKS!), but I figured I had time to do this if I charged the battery (float charger, 2A, automatic) between starts.
I used it last to cut a field, about an hour of use. That day it seemed to get harder to start, as if the battery was getting weak. I then parked it for about a week (without charging, float charger said "charged" battery) and went to start it again. This time the starter turned over very slowly and then just stopped. I checked battery with voltmeter-- read 5.4v, so I hooked up a 6v charger to it and went on my way.
Now, battery reads 5.9v but starter still will not turn over (might get a click out of it).
I know I have to correct the wiring problem (actually, VR and Gen don't even have wires connected) but shouldn't the tractor run OK with me charging the battery after using the tractor? Or does this sound like a deeper problem, like a bad starter or defective battery?
I appreciate the help!
wfd2
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
