You've got a bit of a mess but don't lose your head. It happens. And there is a way out.
A few questions. How much of the drill bit is in there? Is it broken off flush with the face of the broken off allthread or sticking out? Same thing with the allthread. How much if any of it is sticking out the front of the crank? How far on is the pulley? Can you get it back off?
I'm the sort of guy who's cleaned up enough cobbled-up messes that my conscience won't let me leave a mess for the next guy. If the pulley is all the way on, you could leave it as is and run it, but that allthread is only gonna become harder to get out over time.
Getting it out will likely mean pulling the pulley back off for starters. If it isn't all the way on, a little fast heat from a Mapp torch should loosen it up enough to get it off.
From there a lot depends on the answers to the kinds of questions I posed. It could be as easy as a larger carbide (i.e., HARD) bit to drill out the stub of the drill bit that's in there, and then using a left-twist drill to get the allthread out. Worst case would be having to weld a nut over the allthread, snapped-off bit and all, to get the whole mess out at once. Welding on a crank is always touchy and at the lest will mean a new seal for the timing cover, perhaps more. But there's a lot of options/possibilities in between.
Bottom line . . . it's all fixable, but more details will generate more good ideas to get you out of your fix.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
