Posted by MeanGene1 on September 05, 2009 at 08:33:42 from (204.14.185.168):
In Reply to: Cleaning Zollner Pistons... posted by Crazy Red Power in SE-WI on September 05, 2009 at 07:22:20:
You can squirt the rings & pins with PB Blaster or similar, or soak them in ATF, give 'em a day, tap the rings very lightly around the circumference with a light hammer, repeat until they come loose- patience is the best tool. The pins will free up, too, probably not necessary to pull them out. You can lean the fuzz off the pistons and from the rings & grooves with a soft wire brush, won't scratch the pistons like steel wire
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
