Re: Leaky super A radiator
Posted by ScottyHOMEy on September 05, 2009 at 19:18:02 from (71.241.208.178):
In Reply to: Leaky super A radiator posted by Roddy on September 05, 2009 at 18:51:36:
If it's right where it joins to the tank, I'm pretty sure that's a brazed joint. It'll take some prep work in the surrounding area and a good fluxing, but you could try soldering it. If that doesn't hold, it should be an easy fix for any competent radiator shop.
If it is a solder joint anyway, then solder is your answer. All I'd add is that if it were mine, I'd dismount the radiator and lay it flat to attempt the repair myself. My luck (and soldering skills on large stuff) I'd get the whole thing too hot and the pipe would fall right off.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
