Re: Farmall H miss and throttle issue
Posted by TomH in PA on September 06, 2009 at 16:50:14 from (67.234.49.206):
In Reply to: Re: Farmall H miss and throttle issue posted by A Miller on September 06, 2009 at 08:45:10:
A timing light will flash a strobe light when the plug wire it's clipped onto fires. All you do is point it at the timing arrow with the engine running and see where the notch on the pulley is relative to the timing arrow, the quick strobe light will make the pulley notch look like it's standing still. It helps to put a little white paint in the notch and work in dim light, especially if you have a 6 volt system because the light isn't very bright.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
