I've adjusted the governer linkage according to the little manual I got online, but the high idle adjusting bolt on the top and the screw on the bottom don't seem to make much difference. (I plan on getting a proper repair manual).
I replaced the ignition parts and set the points to .020
The carb is a carter UT and I couldn't find a rebuild kit anywhere so I just cleaned it up and made new gaskets.
Shouldn't that thumbscrew make the engine stumble when it's screwed in all the way?? (I'm pretty sure the one on my KB3 does that)
I checked the compression and it's 90-100 psi on each cyl.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
