Posted by Tom Fleming on September 09, 2009 at 16:06:21 from (67.20.240.67):
In Reply to: 10-20 manifold stud posted by Tony S. on September 08, 2009 at 21:20:05:
I just wanted to follow up about using heat. Yes, cold cast iron does not respond well to intense heat. However, I have sucessfully removed bolts and broken bolts using Mr. Heat, aka the "blue" wrench.
The key is to gradually heat the cast iron mass, and keep intense heat localized to the bolt itself. I have heated engine heads in the oven to 300 degrees, and then used a torch to heat the bolt itself.
Above all, what ever method you use, patience trumps all. It took years for a bolt to rust solidly into a cast iron block or head. 15 minutes will not remove it without great risk of damage.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
