Re: farmall 300 ign. timing
Posted by D Slater on September 09, 2009 at 16:18:56 from (71.164.37.9):
In Reply to: farmall 300 ign. timing posted by c.perkins on September 09, 2009 at 15:44:32:
Turning engine in the dirrection of normal rotation the last mark that gets to pointer is TDC. If you mean the rotor is pointed to # 4 cylinder roll engine agian until the marks come up and it should point to # 1 and number 1 should be on compression stroke. If the 300 pulley has 3 marks the one closest to TDC mark is the total advance mark if its gasoline. If it has 4 marks, next from TDC is for LP timming 16 degrees, next is gasoline total advance 22 degrees, last is for kerosene or distillate engines 30 degrees. One with 3 notches doesn't have the LP mark.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
