Re: Farmall H-DisCharging
Posted by pete 23 on September 10, 2009 at 10:44:47 from (173.87.8.73):
In Reply to: Farmall H-DisCharging posted by Dave42H on September 10, 2009 at 09:07:37:
System should never show heavy discharge at low idle (unless you have a load on such as lights) as the cut out should disconnect gen from battery. This is a problem with using 8 volt batteries, cut out needs to be set above the static 8 volt battery reading of approx 8.4 volts and charging voltage set on regulator portion to approx 9.2 volts. Most people do not have the knowledge of how to do this and although it can be done without special equipment other than a multi meter you have to know what you are shooting for. You need a fully charged battery to start with so voltage will rise to the point where it can be regulated.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
