Butch WI said: (quoted from post at 18:39:05 09/10/09) he has a 2950 JD that he hooked up to it and it lifted the disc fine. But I don't know if the 450 has ever lifted it before. The engine labors when he moves the levers when no hoses are connected but I didn't ask if it labored when hooked to the disc.
Butch
The 2950 has a piston pump, probably 3500psi, a much higher pressure system. Older systems were either gear pumps or scotch-yoke and lower pressure. Today you can get 3000psi or higher gear pumps, but not at that time period... 2000 or rarely 2500psi was high in any ag equipment. If you have access to a larger diameter cylinder, try it. The only other thing, if the cylinder is big enough, would be if the quick disconnects do not match and one of the "checks" is not being pushed open by the mating connector. It would still labor the engine, but flow could not get past.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
