I may be wrong but I got the impression from your last post that you may think the throw-out bearing is the same as the pilot bearing.
The pilot bearing will be a ball bearing pressed into the end of the crankshaft but more likely into the flywheel. They can seize up and eventually grab the splined clutch shaft through a galling action. I had a Cub do that to me many years ago. The main difference with the Cub is that the pilot bearing was a bronze bushing. Your bearing should have made some noise when disengaging the clutch before it seized on the shaft. This is not a diagnosis of what is actually wrong with your 504.
A throwout bearing may have some wobble. The bearing will still be good. It is just the bearing carrier/yoke that is allowed to find its center when pressed against the pressure plate fingers. In other words, it floats a little.
I don't fully understand TA's as well even though I have replaced one and, at the same time, changed the output bearing, flange, shaft to the larger size. I just set them according to the manual.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
