Drivetrain is the same. Whats is different follows. Hydraulic pump and distributor, lines to hydraulic pump, some parts of throttle control, hood sides, radiator shrould, some hand crank parts, air cleaner, conections and mounting, frame rails and engine mount spacer blocks, fuel tank, fuel line, original type oil pressure gage, 12 volt system, choke cable, starter, may have forgot something. If you just want function the fuel tank will work fine by pluging fuel return port and putting a bowl in other, hoods work after cutting a hole for exhaust pipe, frame rails will work, doesn't matter about hand crank parts if not used, choke cable may or may not reach carburetor, fan shrould will be shorter but will work, 12 volt system and starter will work, generator pulley and mount from gas is needed or make a mount, need the throttle rod from governor to throttle lever near air cleaner. hole rod goes in is bigger on a diesel but can be modified, more notches are needed at throttle lever. If it has power steering different mounts are needed. Clutch and flywheel will work. Water pump from diesel will work, but a complete gas engine with most parts along with hydraulic pump is needed. Unless you have a good engine already it may be better to sell the diesel and purchase a complete gas tractor.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
