Posted by Mark Peters on September 14, 2009 at 15:26:58 from (66.222.7.225):
In Reply to: Fast Hitch Farmall C posted by glennster on September 14, 2009 at 08:17:13:
Carl Beck said: (quoted from post at 11:17:13 09/14/09) Is there a way to adjust the two receivers on a fast hitch to gain a fraction of an inch additional distance between them. I have an impliment that is 1/4 of an inch to wide and I haven't found a way to create even that much play between the receivers.
Carl, There is no adjustment on spacing to the sockets on the fast hitch. Both large and small prong fast hitches use the same 28" spacing.Small point FH implements will fit into large socket FH with the use of 1/2" thick filler plates. The only difference between the large and small FH is the 1/2" height difference of the points(3"' high on large vs. 2 1/2" high on small).
My guess is either the bail( the part of your fast hitch with the sockets on it) or the prongs on your implement are bent or sprung.Measure both hitch and implement to see if they are 28" center to center.If either one is sprung or bent, the use of a hydraulic porta power or other method of straightening is called for.Hope this helps,Mark
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
