Re: heater for winter starting
Posted by jal-SD on September 16, 2009 at 19:13:22 from (70.57.233.182):
In Reply to: Re: heater for winter starting posted by Hugh MacKay on September 16, 2009 at 18:36:10:
I put a 1000 W tank heater on my H, used the block drain & plumbed it into the outlet for the heat guage with a pipe "T". Works OK, but the heat guage reads a little low. Don't know why it wouldn't work on an M. Look at the thermostat housing, some have a drain plug below the level of the thermostat. It probably would work to plumb it into that plug opening. (My $0.02 worth. jal-SD)
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
