The carbs are identical. The 450 carb MAY however have a slightly larger venturi insert - I'm not certain.
Only way to adjust timing for absolute max power is to set it while observing output on a dyno.
Otherwise set it per the owners manual or a degree or two advanced using a timing light.
But if a timing light shows the timing is "dancing" randomly more than a couple degrees at speed, find and correct the cause. Otherwise you're just chasing your tail trying to optimize spark timing! (Look for worn distributor shaft bushings, gears, centrifugal advance, etc.)
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
