Posted by glennster on September 20, 2009 at 07:06:53 from (24.14.63.246):
In Reply to: M Farmall question posted by Jerry RV on September 20, 2009 at 07:02:22:
the fill plug for the rear end/trans is right by the base of the shifter. you need a 3/4 drive to fit in the plug to unscrew it. a 1/2 inch to 3/4 adapter works if you dont ahve a 3/4 drive set. on the left side of the tractor kinda by the clutch pedal and brake housing is a small square heas pipe plug. that is the sight hole to see if the trans is full. the belly pump holds about 6 qts of either 30 wt motor oil, or, i run hy-tran in my pumps. the belly pump is seperate.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
