806 should work fine on a one way cyl. Use the outlet that will lift the one way cyl when you put lever into the forward, (down position), and then to lower cyl put lever way down into float position. Only reason this won't work would be a coupler problem, check valve block in system or load on cyl not enough to lower itself. You can leave in float position when down if your equipment is positined where you want it to be and then just flip lever back one notch to raise.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
