Are the wheel bearing tight or loose. Should be snug. Are the rims bent? Jack the front up and spin the wheels. Watch the gap between the tire and the ground. Loosen the bolts and adjust until the rim on the wheel is centered. The rest of the slop is in the joints of the steering shaft and the worm gear in the bolster. Some of the steering gears can be flipped around to put teeth with less wear in contact with the worm gear. You may be able to tighten the bearing on the end of the worm gear. Which will help alot. SDE
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
