The smoke when running on gas may be due to fuel not shutting off completely. Make sure lever on pump is fully against internal stop when throttle is in shut off positon(can tell by just feeling of the lever). You could open the bleeders on all injection nozzles when starting just to see if that helps. That could tell you if fuel is being injected during start up if the smoke clears with bleeders open. Note, even a correctly adjusted pump will deliver fuel through the bleeders as there is no resistance to fuel flow when bleeder is open. There is no positive shut off in the pump, the plunger is rotated to the point where not enough pressure is developed to open the nozzle. That adjustment is done by adjusting the rack internally. Far as ignition timing, set static timing for tdc and when it is running on gas, you might get it to run better by playing with the timing, tweaking distributor back and forth for max speed, always staying with the most retarded positon possible. The other adjustments on manifold etc for gas start rarely get out of adjustment but it is possible.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
