The tractor that I was going to take the valves off of, Had two pipe plugs in the front of the first valve body, just as you described. It has a Ford power Steering pump powering a Char-lynn actuator, so it does not need to use that valve at all for the P.S..
The first valve on this tractor did not have any openings in the front of the valve body.
I thought that the Behlen P.S. system got its power from the bottom of the Safety/regulator valve. Can you tell me about that so that I can put the correct valve back on this tractor? I have a Behlen system also, that is not working now and maybe I need to swap this one valve to get it to work. SDE
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
