The only thing here is that the org. Amp gauge is only a 20 amp gauge and if you have and alt. on it when she goes into full charge depending on the amp rating of the alt it will peg the gauge and i have seen them stick the needle . The light switch will take it as the higher the volts the lower the amp.'s When i make a change from a 6 to a 12 i replace the main wire from the gen to the amp gauge and from the amp gauge to the starter switch with a 8 ga. wire as the old 10 ga. will work but i feel better with the bigger wire . But i am the type of guy that when fabbing something if 3/16ths would work then 3/8ths is better .
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
