Three items. The shredder has an optimal RPM when used, This is not likely to be 540rpm of the PTO.
The PTO should drive shaft to the shredder, not a belt. Belts on three point systems will not be able to be adjusted correctly, as changes in hitch location will change the tension.
The use of a right angle gear box with an appropriate ratio to drive the shredded would do it.
I would consider using a separate engine on the shredded.
If you are good with fabrication, a differential with its spider gears welded, shortened, with one axle cut off and capped over, could be used. Driven from the axle , and power taken from the pinion, would increase speed, and make a right angle. This is however an engineering task, with welding and structural challenges. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
