Posted by D Slater on September 27, 2009 at 20:30:23 from (72.65.129.239):
In Reply to: M engine swap posted by 41106 on September 27, 2009 at 17:59:24:
Unless you have a late M with a 12 inch clutch or a late belley pump housing to clear the 12 inch clutch. Use the M flywheel and clutch. If you could use the 400 size flywheel and clutch the clutch plate needs changed to a SM type. Switch throttle arm and shaft on governor. Run vent line in top of valve cover to air cleaner intake pipe vent line opening. Depending on what model M it is and if a live hydraulic pump is used or not a ignition drive housing and shaft from a SM or late M may be needed to match the 400 front cover bolt pattern. If using a 400 carburetor the choke lever will be toward engine instead of out like a M. So choke rod will need a little work. Sometimes the 2 head studs where the M throttle bracket mounts are not long enough on a 400,450 to have full threads on the nut after bracket is added. Stock ignition unit for a M may have to much advance for a 400,450.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
