Posted by Mike CA on September 27, 2009 at 20:40:33 from (99.28.152.102):
Between the belt pulley drive housing and the bearing cage there are shims for the belt pulley. In the parts guide it shows 3 shims, in succession, heavy, medium, and light. Tonight I pulled apart those shims to clean them and I found a total of SIX shims! 1-Heavy, 1-medium, 4-light (best I can determine).
Gordo told me I could pull a shim off if a particular spot was getting worn on the gear teeth. Well, I don't see any wear.
So, why were there 6 put on? Why do I need any shims? Should I put only the 3 on that the parts book shows, or should I put all 6 back on? I'm putting sealant between each shim to prevent it from leaking again. So maybe the sealant will make up for half the shims width?
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
