It could also be valve adjustment, but Jeff has a good idea for the first and easy thing to check out.
The other common places for air leaks are at each end of the manifold -- where it joins up to the head and where the carb mounts on the bottom. Those can usually be fixed by either tightening up anything that's loose or replacing a deteriorated gasket. Worst case is a rusted-through manifold, which can sometimes be repaired but often is easier to just replace.
The easiest way to test for leaks of this type is to get your tractor started however you have to, and let it idle. Before it gets too hot, take your starter fluid and spray around the places where it might be leaking. If it picks up speed any, you've located a leak.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
