Last night and tonight I revisited the generator. With the armature in, it showed a short from the field post to the case. With the armature removed, it showed an open from the field post to the case (?!) Obviously, the armature had something to do with what was going on.
I noticed that the screw holding the terminal for the brush wire to the armature post was a little loose. Lo and behold, the same loose screw had allowed the wire from the armature post to the field coil to move around enough to contact the commutator, which had worn j...u...s...t enough insulation off the wire to create a field-to-commutator short.
So I snipped off the field wire's terminal, replaced the old insulation with some 1mm i.d. heat shrink tubing, soldered on a new terminal, and carefully rerouted the wire about 1/8” from the case and far from the commutator.
Now the field reads 5.5 Ohms. The generator motors fine, and speeds up when the field isn't grounded – just like it should!
Next (after payday) will be a new U.S.-made regulator of the correct polarity, a complete check of all the wiring, and likely a new ammeter.
I just want to say thanks a ton for your help and explanations. It's also good to know this issue will hang out in the archives just in case the same problem bites someone else in the future.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
