Posted by rustred on October 02, 2009 at 07:03:18 from (209.115.232.65):
In Reply to: fuel leak on M posted by nydolphin on October 02, 2009 at 05:19:48:
most probable cause would be needle&seat. it is located at the carb inlet behind the brass screen. BUT you need to remove carb and separate halves and remove float, by pulling out pin. then you can remove needle & look at it. the metal ones usually show the wear where its seating. the seat unscrews. best to just o/h the carb, as you will need to soak it in carb cleaner to dissolve junk out of it.after soaking wash in warm water and blow out all passages with air.rest later.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
