if you're going to be shopping around at other than a CaseIH dealer.
That 11/16" inside diameter is commonly referred to in a "nominal" size as a 5/8" washer, i.e., it's made to fit around a 5/8" bolt. Trick is that it's quite narrow, about 3/32", much more so than a common washer.
It's fading some, but the more common application for that type of washer is on automotive motor oil drain plugs. Second trick is that a lot of those anymore, where they still use them, are metric.
The thought is that you may be able to find one locally for that application. If you have the center bolt out anyway, take it with you and try a 5/8"/16mm drain plug gasket for fit. It might just do the trick.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
