Posted by Jeff 140 on October 03, 2009 at 05:43:25 from (71.58.184.152):
Hey guys,
I want to start out by saying what a great forum this is. Has helped me alot with my 1941A & 1964 140 indsutrial. I have a 1964 Farmall 140 with a 6V charging system, generator, distributor etc. wired for positive ground. The system was not charging, so I decided to get the system rebuilt. Here is what I have done so far: Generator rewound at local shop (was tagged neg ground when I picked it up) - New voltage regulator for positive ground - new battery cables for my 6V battery (hooked up positive ground) - followed all wiring per International IH570A diagram to make sure mine was correct - removed light switch & fuse holder as tractor has all lights removed and I wanted to simplify the wiring - cleaned generator & regulator mounting areas for good ground connection - after mounting & wiring everything, I polarized the system as described by John T in so many of his electrical postings on this site! - polarizing the genny should take care of the genny being marked negative ground by the rebuilder ????? - when I pull out the ignition switch, the ammeter reads approx -10 discharge - when I start the tractor, it reads approx -10 discharge - if I ground the "F" terminal on the genny, the ammeter gets burried to the positive side, and the battery reads 8V across the terminals - the battery reads 6.3V before starting and after starting without the "F" terminal grounded - I tried running a ground from the battery grounded terminal (+) to the genny and then to the VR with no change in results - suggestions ??????????????? Help !!!!!
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
