Re: New Farmall 450
Posted by pete 23 on October 03, 2009 at 20:41:32 from (173.87.8.73):
In Reply to: New Farmall 450 posted by SCpuller1 on October 03, 2009 at 19:21:35:
Most likely a 450 won't have a seasonal disconnect but it may have. Most run the pto in the engaged position if they don't need it as the planetery gears are turing at a lower speed than when disengaged, however, I would make a shield with a closed end over shaft if I was to do that. Also, the pto rear unit is a self contained unit so fluid is seperate from rear end. Often times it never gets changed. TA, your call, use it as needed. Direct drive has least amount of moving parts.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
