Posted by D Slater on October 05, 2009 at 06:06:33 from (72.65.137.34):
In Reply to: Stuck Clutch Pedal posted by JeffnPA on October 04, 2009 at 20:11:51:
When you say pedal, I take it you have a industrial 6 with a foot clutch and the pedal stays down even when foot is removed. If you can't see a problem on the outside. Unless something unusal happened to make the pressure plate stick in the released position the fingers should push pedal back most of the way, enough for tractor to go. Would check the sleeve the release bearing carrier slides on, fork and carrier for breakage or other problem blocking pressure plate engagment. You may be able to see whats happening through the inspection hole on bottom. If not the top of clutch housing will need removed.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
